Brwmogazos said:the 3.4 chips seem to be the best clockers arround
They are all D1 stepping and have 30 caps.
they cost £300 so thats why i didnt touch one...its the price of 2 3.0Cs wo better get a few 3.0Cs that with a bit of luck will have a 3.4C corein them and try again...
axer if youre not getting good contact then i am sure this will be limiting your clock too...
no good contact is high temps, cpu not cooled properly, lower overclock-bad stability
But that was probably b4 the vdroop mod which i think is a big issue for the p4c800name='aXeR' said:i spoke to phil a while back and he said his 3.4 he had reached 4.1![]()
gorby said:But that was probably b4 the vdroop mod which i think is a big issue for the p4c800
These chips dont like mroe than 1.8V, but with the droop done well that wont fluctuate lower than 1.75 with 2X prime
but dude there’s a chip out there some where with a higher multi that will do the same fsb.. surely this is no time for safe bets!name='Brwmogazos' said:i think i am gonna push it up to 1.75V for 24/7 then... and 99% its the cpu i am keeping due to the lower multi than my 3.0C
