Hello All
Well couldnt resist buying one of these baby's and i must say first impressions say they are all they are hyped up to be
It is a AMD Opteron 146 Cabye 0540 FPAW.
Only had it in for a hour and got it clocked to 2.7ghz on stock volt's and stable, Take a look at some screenshots:
I dont know if you mind pictures this big but i can link them if you want it 56K friendly.
I am impressed with it so far and will up the voltage later and try to hit 2.8ghz to 2.9ghz or maybe even the magic 3ghz but i am only on air. I am using a Arctic Freezer 64 (not pro).
Sam
Edit
I got to 2.8ghz (AMD FX57 Speed, £700 CPU) after upping the voltage to 1.475 in the bios:
Sam
Edit
I have just done a Super Pi 32M test at 2.8ghz on 1.44V (set to 1.475V in bios), Here is the result:
All seems stable and my memory is running exactly at 200mhz.
I am going to leave it at that for the minute and might try for more later, During the Super Pi 32M test is sat at 50C sometimes hitting 53C but coming back down to 50C, Is that ok?
Sam
Edit
Couldnt resist pushing it a little further
I tried 2.9ghz on the same volts and it was 100% stable in Super Pi but as soon as i did a Prime 95 Torture Test it got a error so i reduced it to 2.85ghz and this is my outcome:
It is 100% stable after 45mins Prime 95 Torture Test and several 1M Super Pi test's and 1 Super Pi 32M test.
Might try upping the volts tomorrow to reach 3ghz.
Sam
Latest
Here is the latest clock on my opty 146, Notice the core speed hasnt changed but the voltage is lower:
Still a bit unhappy with the super pi 1M score.
Sam
Sam
Edit
Sam
Edit
Sam
Edit
Sam
Latest
Sam
