maverik-sg1
No if it says GT on the back then its a GT - the compressor used by Nventiv/ECT is usually used for r134 - take no notice, its r404a gas in there.
Good to know about BIOs flashing, although I said for FX60 compatability, I had no idea there was an issue with the latest nvidia cards. Right fix with wrong diagnosis lol.
Okay well firstly u gotta find a temp monitor for the asus board that reads negative temps - asus probe (I think) if the temp is negative then the probe reads 200+ degrees, take 260 off the value to get ur true temp it's not ideal but I don't knwo what else you can use otehr than ur BIOS.
Okay anything higher than +12 degs fully overclocked (benching) is not good.
Anything over +1 for everyday overclocking is not good - try to stay sub zero for everyday use.
Mav
Mav
