Hi all...
During my messing with a cobbled together AMD box...
Athlon X2 7750 BE, Asus M2N32 WS Pro, XFX nVidia GTX260, 4GB DDR2... yadda yadda...
I've hit an odd limit where no matter what clocks I increase - my benchmark results aren't going up as much as I'd expect...
The chip's at 200*15(3000)...the card's at 700core,1490shader,1275ram...the ram's at 4-4-4-12 2T...
If I up the graphics card...the benches don't improve (3dmark vantage, 06, 05... you name it)... and game frame rates don't improve any.
If I up the chip... either to a higher multiplier *16 (3200)...same story... (pi calcs don't get any faster) ...and the same in games.
...or if I hammer the FSB and run at 250*12 or *13 ...same story (even though the ram's now at 500...) ...same in games.
The ram controllers produce near enough the same results whether I'm ganged or unganged.
Regardless of what I change...the bench results and game FPS don't waver more than 3-5% and I put that down to Windows being twaddle...
I can't get the ram to play ball at 3... so that's out the window...
Has anyone any ideas of what's choking it up... I'm on a geriatric board... but I can't see that with this system the bus has gotten full...
EDIT: Stock, the system is at 2700 (fsb 200)... the card's 640 core (can't remember the ram/shader speeds)... Since I went past about 2950 on the chip all's I end up getting is a warmer room...
Answers on a postcard... the wackier the ideas the better...
