my fittings aren't hurrying up. Enjoy being on top of the leader boards while you can.
I've no doubt in my mind I will be shunted off the top spot soon, I look forward to it, it's going to be fun.my fittings aren't hurrying up. Enjoy being on top of the leader boards while you can.
I would push it to 5.5ghz+![]()
You would cause a fire and burn down whatever city you live in.
I've done 5.3ghz before, and had a first gen i5 on 1.7v, no fires yet![]()
Might just break out my ol' seidon 120 and get some benching done as this watercooling lark is taking me forever to get round to sorting out.
Sounds like a plan dude, I might disassemble the rig and prep her for something spesh... my mind's in mod mode right now.
H100i mod like Tom did?
I have my rig set up and running. Haven't had any time to give it hell. Hopefully this weekend.
Had it up to 4.8G@1.37volts. I think I can get more out of it with some time to play. Then I'll validate it.
Came here hoping to see some good overclocks on the G3258, but this thread has not been used much, so decided to post my initial results.
Just got this cpu while I wait for the i5 Broadwell. I also wanted to experiment a bit with overclocking before getting the more expensive cpu.
First overclock went very well, 4.3 GHz at 1.200 core voltage. I am using a Corsair H105 and the temps have been really good. 23C at idle and 55-58C at load running prime 95. Let it settle for a bit and I will try a higher overclock.
http://valid.canardpc.com/3u8hrm
