Hi all,
I have overclocked my Asus Extreme mbb with 4770K to 4.5 & 4.8 GHz. However the overclock is not shown in the Windows OS (7 64 bit). When I restart or turn off my PC and go into the BIOS the overclock is saved.
When I run various utilities such as CPUz and increase my CPU load to 100% the max it goes to is 3.8GHz.
Ihave tried resetting CMOS but no luck. I have the OC panel connected which reports 4.5 and 4.8 when in the OS. I have tried running just AIDA64 on its own and it is still giving back the same results.
In the BIOS:
AI OC Tuner: Manual
CPU Core ratio: all 45
EPU power saving: disabled
Fully manual mode: Enabled
CPU core V: 1.25
The rest all Auto or default. Have also tried with the XMP profile.
thanks for any help.
HWiNFO64 by GodAtum, on Flickr
In the BIOS:
AI OC Tuner: Manual
CPU core V: 1.25
