NZXT Switch 810 Build/Mod Log
Oh of course my bad I just assumed incorrectly that you were in the United Kingdom! - My bad for not reading your location under your profile.
Unfortunately I have no idea where you would source these parts in New Zealand and I'm not sure if Scan will ship there but I'm guessing they wont. I feel your pain living in NZ for stock of stuff I know how hard it can be to get specialist parts there due to its remoteness.
Haha, na man, New Zealand and proud
no problem man,
yeah i know right, its such a shame that our country receives sweet F*CK all of stock,
i saw one on ebay, but at 450usd, i do not think i would go near it !!
I might email Scan and ask if they would ship overseas
Thanks for the replies !!
Yeah, NZXT Said "no no, the front cannot fit a radiator in it, that is what the bottom is for" well i say "CHALLENGE ACCEPTED" The holes for the rad do not line up, so i will have to dremel in some notches so that it is not only screwed in by the bottom fan mount
Case will look better with a rad in the top, and the gpu's in too, then i will add the green dye, and my cathodes too
and S_I_N, i go for the awesome/overkill look
Well, sometimes it's good to be wrong!
I'm glad someone took the initiative of trying to get a 360 in the front. I can't believe you did, but you did! That's pretty awesome!
So, here we are ladies and gentleman !!
my rig 95% completed
all i have to do now, is get myself a fan controller, and a waterblock for the GTX680, sleeving is great !! really happy with the way everything has turned out
Please let me know what you guys think !!
Please note: after taking these pictures, i realised i forgot something
does anyone know what it is?
That looks amazing... Might have to do a green build next
If you don't mind me asking, what did you use to sleeve your cables?
Also, does the switch feel like a solid case? Thanks
Well done on an epic rig
Hey thanks !! yeah green is a good colour if you ask me
Yeah man sure !! i sleeved my cables with the one and only MDPC-X sleeving
wouldnt go anywhere else !!
Yes, the Switch 810 is solid, a little plastic'y, but overall, very very solid
Thanks for the quick response,
Yes i might to go green next time now I have seen what can be done
Thanks for the sleeving company, I will definitely check it out. Would use cable extensions but much prefer the idea of doing it myself, much more of a sense of achievement
Might have to have another look at the switch for my next case, it looks really nice in those pictures...
Enjoy your build
