NeverBackDown
AMD Enthusiast
Well look out for both.. if the GPU power rises so does the power from the wall
Afaik it only effects the 165hz GSYNC monitors a lot because the core clock goes upto 800mhz to drive the refresh rate. Other than that normal 60hz 3/3+1 setups probably don't make much a difference I'd assume unless you can look into GPUz and see if it does indeed consume more
