[font=verdana, geneva, lucida,]The DDR5 version can turbo to 835Mhz it will never go higher no matter what you set it at at the moment Afterburner will let you set it to 880Mhz but if you bench it with furmark and watch the core speed it tries to turbo to 970Mhz which is a 90Mhz increase like from 745-835Mhz, (if you set it to 880 it will try to turbo to 970Mhz.)[/font]
[font=verdana, geneva, lucida,]But it will throttle it self to 835Mhz it WILL NOT go above this no matter what you set it to, so you wont be able to overclock anything bar the memory.[/font]
[font=verdana, geneva, lucida,]Will there be an option in the future to disable turbo mode?[/font]
