name='Mr. Smith' said:Shure E2C - sound mint and come with loads of nipples for the ends.
The expanding foam ends are akin to ear plugs... Can be had on amazon for less than £20 delivered...
name='Jim' said:Cheers for the suggestions guys. I'll go check em out (even the nipples :yumyum.
Reps all round
name='Mr. Smith' said:Bloody hell Jim, you've given out reps! You never give out reps! Ta mate.
Was it the nips that did it?
name='Fatal M' said:well if u didnt buy those already ! i just wanted to give u a couple more options !!
now what i have and using at the moment is the Fatal1ty Headsets !
those babys are awesome
check out this link here and check the specs im sure ull like emone of the things that will cancle noise is that the cord is Oxygen-Free Copper !! so more noise canceling !!
iv been using them for over than 2 month now and using them for almost everything and they are excellent
but one of the bad things is that it makes too much pressure on the head but u loose the feeling after a while
hope i helped out
chears
Fatal
name='Bungral' said:I bought that exact same headset about 1 - 2 months ago from amazon.. used them for a week or so and it was all fine until I used them for about 3 - 4 hours plus and it hurt my ears quite a bit.. Then the day after a shorter period caused the same pain as they hadn't recovered so I decided to send them back. All good for short to medium use and of good quality but for long gaming sessions not so good.
