Noctua D14 + Corsair 350D
TheUnkn0wn
I've decided to build a new smaller rig using the Corsair 350D (I've not bought anything yet). I'd like to fit fit a Noctua D14 in it, it should fit (I think :confused:) but I'm just thinking whether it would cause any other problems and if its cooling would be affected?
Has anyone actually done this? If so could they provide some pictures?
350 is 8.5" wide and the D-14 is 6.3" heigh, so will easily fit.
Awesome, this means I wont have to spend any money on a new cooler since I can use my current D14.
I'm just curious if I will run into airflow problems? The 350D is quite a small case and the D14 is quite a big cooler :(
I don't have pictures to show yet and I don't have that cooler anyway but I do have the case and I'm sure it can fit the NH-D14 without any airflow concerns. For an mATX case this thing is very spacious IMO.
