I need a bit of help please…
I've installed my new bits of kit and when firing it up for the first time it won't go into Windows (XP home).
I have changed the following:
Mobo: Bad Axe 2
CPU: E6700
GC: X1950XTX
Mem: Kingston Hyper KHX8500D2K2/2G
PSU: Enermax Infiniti 720w
The rest HDD and DVD drives etc are from my original PC.
It all starts up ok and the only error I can see is "No array found!"
It's says new hardware detected, but just goes round a loop of asking if I want to boot in safe mode, safe mode with network, safe mode with DOS, last working version or start up windows as normal? Which ever option I choose it just goes around the same restart loop.
I do have a Windows recovery CD do you think I need to run this? I don't have a full version as it was pre installed on my original PC.
If I do have to run the recovery CD is it just a case of changing the drive detection to look at the DVD ROM first and it runs from there?
Sorry if this is an obvious problem with a stupidly easy answer I did search the forum first, but couldn't find anything on this?
Thanks for any help from a noob on first ever build.
Mobo: Bad Axe 2
CPU: E6700
GC: X1950XTX
