New Rig with i7 3960x
Jpsika08
Hello, this is my first post of hopefully many more in the future.
I have had experience with computers since I was 9 years old (35 now). Some years back I went from custom PC to Alienware, recently, the little custom bug began again and took the plunge on my new rig, this is the list of things I just bought, though, wanted advice from you experts if everything will work or missing something:
Case: CoolerMaster HAF-X
PSU: Corsair Professional series Gold 1200W
MoBo: ASUS Rampage IV Extreme LGA2011 X79
CPU: Intel i7 3960x Extreme Edition (3930k was not in stock nowhere so I took this one, over payed
CPU Liquid cooling: Corsair H100 (Will this suffice?)
GPU: HIS Raedon HD 6990 with 4GB GDDR5
Memory: Corsair Vengeance DDR3 @ 1600 32GB Total RAM (8 x 4GB Modules)
SSD: Corsair Force GT 120GB Sata 3, 6GB/s
HDD: Seagate Barracuda SATA 3, 6GB/s, 1 TB @ 7200 RPM
Misc: Dell High Speed SATA DVD-RW
Peripherals:
Monitor: Viewsonic 27" HD 1080p, 3ms Response, 60,000:1 Dynamic Contrast
Keyboard: Logitech G510
Mice: Cyborg RAT 7
Am I missing something besides the OS?
Thank you for any recommendation.
Merry Christmas to all BTW.
I would change the case and cpu cooling. The design of the Haf isnt very nice, but it do have good airflow. When it comes to chosing case its very personal, so its hard to give advices on that. As long as the case have good features and good airflow its all good really. so il leave that up to you. A NH-D14 is mutch more easy to use then the H100. the radiator needs to be cleaned pretty often and you never know how long the pump will last. The H100 is pretty noisy on max, while the D14 is always pretty silent. Though, the D14 is pretty large compared to any WC.
Also. AMD have launched new gpu's and the 7970 is doing pretty good and in some tests its actually beat the 6990. I would get that or a 580 from nvidia.
Is nearly the exact system I am building......
I already have the Rampage I'V Extreme. (although it's going back as a couple of pins bent in the socket, wasn't me.... As I don't have CPU yet)
Mine is all going in the Corsair 600T (which I love, but as azurite said the case is a personal choice)
Memory I went for the G.Skill Ripjawz 2133 MHz
Hope this helps
Azurite, thank you for the quick response, problem I have is that I'm not within the US and I already ordered everything, returning any equipment at the moment would increase the build cost a lot.
I will check out the D14 over at frozencpu.com, it's much more bulkier than the Corsair H100, though, seems that it does a very good job.
I saw the 7970 announced after I ordered the 6990
Will see how it goes.
Thanks
A couple of monitors...? =P
Totally agree, next installment. Thanks
Hope this helps
Sorry to hear about the Rampage, hopefully mine doesn't come likes this as sending it back is a little complicated on my side.
Do you have a thread going on for this new build? would love to follow along, there are a lot of things I want to learn for my build.
Sorry to hear about the Rampage, hopefully mine doesn't come likes this as sending it back is a little complicated on my side. Do you have a thread going on for this new build? would love to follow along, there are a lot of things I want to learn for my build.
I don't atm as I haven't brought CPU yet, but sure when I get going with it I sure will
Thanks
[/quote
Im sure you be happy enough anyways. Its just minor changes anyways. Know severalpeople who use the H100 and they r super happy.
Looking forward to it.
If you like the look of the HAF-X, have a look at the CM Storm Trooper. Much better case IMO.
Thanks,
Thanks
Thank you and thanks for all suggestions.
I have doubts that the d14 will fit over the ram. I think you'll be better off sticking with the h100. Honestly, I think you'll be just fine. GLHF =]
