New phantom build
Streipsgjen
This weekend i finished the phantom build for my brother. He got some components but he wanted to watercool his whole pc so i helped him with some ideas and after i got al the components i build this machine for him
It isn't completely ready yet because i have to ad a second video-card(soon gonna be replaced) and he is gonna replace the ram.
it got a Asus Crosshair 4 extreme with a AMD Phenom 2 x6 1090T en till now it has to 5770's in crossfire. My brother is using him now but when he got his new video cards he's gonna bring it back to me so i can finish the set. You can also see that he ordered triple channel ram by accident so we need to replace that to for a dual channel set.
All waterblocks are from EK but the motherboard block is from mips. With his new video cards im also gonna make the sides of the Acetal top of the blocks white i think that can look very nice.
Till now im pretty happy with the result so far and the Phantom is a nice case to work with
Looks really good mate got one question though, why did you put the cpu loop under the gpu power and the gpu out tubing? Was that the tidiest way to do it.
the pump is standing at the bottom and from the pump i go to the CPU so that was a bit long end and the hose was a bit curled so it was pushing away the hose from the GPU to the radiator, so to not push the GPU hose out i enclosed the pump->CPU hose behind the power for the card. I agree that it isnt looking that great but one curly hose was enough for me
