well after creating a new home office/gaming space i now need to get started on making a desk and other bits for the room.
spent a few weeks planning the build and now have most of the issues worked out i think.
desk design so far: -
desk length will is 2788mm long and will be made in three parts, desk is also 620mm deep which should give a good surface area for when working with drawings, wiring diagrams etc
Main view: - front
Main view: - rear
Close up of pc area
Top Push To Open Draw
this draw will be home to the power and rest buttons, power switch for a 3rd psu to run lighting and linear actuator so its all out of sight and keeps it all looking clean, it will also store keyboard, mouse, headset and gaming pads to keep the desk clean and tidy when not in use and will be held in place with a foam insert
Bottom Push To Open Draw
will be home to the water cooling radiators, im not overly happy with air vent holes in the draw front so i will have to brain storm a new way of getting cool air to the radiators.
Heads up Display
will rise out the back part of the desk giving access to the fan controllers, front USB ports as well as temps of the pc area, radiator area and water temps. you will be able to raise and lower this unit via controls in the top push to open draw and also be able to turn the whole lot off when not needed
room layout once completed
main wall with pc desk. will have two 27" monitors for pc's and a 32" tv for watching tv and viewing CCTV feeds
opposite wall will be home to some storage as well as two printers
things i could do with some advice on at the moment are
1: - i can not seem to find a io shield holder/mount any where, i have one from my last desk build.
2: - best way to change from hard line water pipe to flexible tubing
3: - also unsure at this time on colour scheme, i know that i want to use grey as a main colour but unsure of what colour to go with it.
at the moment im leaning towards a main colour of grey with a metallic copper colour inside or metallic copper highlights
this wont be a very fast build when i get started as i can see some stages taking a long time to complete
Desk construction: - 14 to 30 days to build the desk
paint prep: - 7 to 14 days
painting desk: - 50 to 60 days
painting finishing: - 7 to 14 days
and then the fun part of putting the hardware in which ive not yet got 100% sorted out
Main view: - front
Main view: - rear
Close up of pc area
Heads up Display
