New mobo upgrade next month.
Acid90
Next month I am planning on upgrading my mobo to something which can hold overclocks better, looks good and can support crossfire.
I've been looking at the DFI LanParty Dark DK X38-T2R.
What can you guys recommend?
I'd recommend chucking in the extra £10 and getting the X48 version. Simply because its only £10 so you may as well.
Other than that fine choice.
Where can the X48 version be had? This mobo I chosen is £120, I am sure the X48 mobo is alot more.
Got any links?
£120? where from? You sure that's not excluding vat?
I can only find the X38 on scan, prices are from there.
Oh damit. I was looking at the LTs, not the DK.
The only quible with the DK boards is 4 phase PWM really. Its a bit lacking for quads, but if your intending on using the 8200 in your sig it should be a good choice.
Just don't be intimidated by the bios options :p.
Haha, yeah I am not going quad until the new socket. Dual core until then! :)
So it should be ok yeah? I think its a good price. My only worry is everywhere says the DFI boards only support upto 800mhz memory? Seems abit stupid.
And are the overclocking options THAT advanced?
DFI overclocking options are deep to say the least. But it's like anything, with a bit of time you'll get to know what does what with no hassle.
'Supports 800mhz' just means overclock me tbh :D.
Alternative would be the IP35 Pro, which tbh is fantasticly stable.
Or one of the P5Q range (-E or deluxe are in your price range). The dlx did well in the labs.
