New Mini ITX build
Freedom
Hi everybody. I just built myself this Mini ITX PC, here's a list of the parts and a couple terrible phone pictures :)
Motherboard: MSI A88Xi AC V2
CPU: AMD Athlon II X4 860K - 4Ghz
Ram: Corsair Dominator Platinum - 2133 Mhz 9-11-10-27 1.5v
GPU: MSI R7 370 Gaming 2GB - 1125/1400 Mhz
SSD 1: Samsung 850 Evo 120 GB
SSD2: Samsung 850 Evo 500 GB
SSD3: Crucual M4 256 GB
CPU Cooler: Noctua NH U12S + Corsair SP120 QE fan
Powersupply: Corsair CX600M
Case fans: 4x Corsair AF140 QE
Case: Phanteks Enthoo EVOLV ITX
*Note I had the ram & the Crucial SSD before I began the build.:)
I had to change the CPU cooler and the ram along with it. The tower was touching the GPU, and the Dominator's wouldnt fit with the new tower a CM 212 Evo so they are replaced with Kingston HyperX Savage 2400 Mhz CL11 1.65v memory
I know it looks like the heatsink is still touching, but it's not and also the card isnt bending as much as it seems to be on the picture. The lighting is also cheating, it's not very sharp at all, I think the phone camera just isnt good at picking up lighting
My pics are being rejected, probably have to make them smaller
Are you using an image hosting site like imgur or trying to add them as attachments to your post? I'd recommend using imgur or similar. If you are already trying that, PM me the links and order of the images you want and I can add them to your post.
He is using the OC3D uploads by the sound of it
The lighting on the pictures isnt what it looks like irl, the phone messes it up completely, it's actually only a shallow hint of dark weak red when you look into the case, idk why the phone messes it up so bad ^^
