ruthless_villain
the OCZ zx range are meant to be really good i wouldnt worry about getting one of them
I need 120mm fans for my 360 rad.
Front case fan, the BitFenix Spectre 230mm = 115 CFM @ 20dBA = $22
3x fans on rad, the CoolerMaster 120mm Silent Blue = 90 CFM @ 19dBA = $15
Fan you suggested (which won't fit on rad) the CoolerMaster MegaFlow 200mm = 110 CFM @ 19dBA = $35
Also, the Smart Response give better overall performance. I don't just want to run a few things plus the OS off the SSD and have everything else on the hard drive... Also, a bigger SSD cost a hell of alot more. The Vertex 3 60Gb has read up to 535mb/s, and write up to 480mb/s.
The BitFenix Spectre 230mm is crap. The MegaFlow is not. Stats might look similar, but boy oh boy are they misleading. The Spectre's are a hell of a lot louder than 20dB, and a hell of a lot lower than 115CFM. The temperature and noise changes I got when I replaced the former with the latter speaks for itself (5deg C lower GPU idle, 3-4 lower cpu idle).
not that shroud, get the ones that look like a fans frame, they are like 4 bucks each.
Get distilled water, PTnuke and/or Killcoil and Mayhem's Dye If you want colour.
