Other options but slightly over budget
Fractal R3
CM 690 II ADV
plus 5 more posts and you can get FREE DELIVERY from Aria
Thanks for the reply, also i had noticed the free delivery from aria before hand
(Awesome deal)![]()
Hmmm, still a tough decision to make i do like the 690 II advanced (strong possibility)and the R3, but the R3 is just that bit too expansive![]()
Think the HAF 912 is a great case, the CM Storm enforcer is also in that price range and is very similar to the HAF.
Thanks guys,
Ok so it looks like a choice between the HAF 912 and the 690 II ADV
But what to choose![]()
Just seen Toms review on the fractal arc.... and well i kind of like it A LOT![]()
looks like i might get that then![]()
Dose anyone know when the Fractal define Arc actually gets released, and also will aria be stocking it?
Thanks, Chris
I did some checking earlier and all I could find out was late June or early July but i'm guessing it's late June seen as there are already reviews out there. Hopefully Aria will have them i'm buying it strait away when they do.![]()
