Goggle Eye
What is the best placment for 2 reseivors?
I do not want to drill any holes in the case.
I am installing 2-360 rads verticle fittings on top, on the front panel in the left and centere blow holes.
I am considering placing one reseivor on the M/Board Tray (Loop One).
Then I would have to run the sata cabels on the back side of the reseivor. It would be very difficult to install Sata Cabels but they will fit. I would also have to fit the 24 pin cable behind the reseivor.
I would have to drill 2 holes in the M/Bioard tray.
Hooking up one Uber 655 pumps (Modified Swiftech 655 Pump) would mount directly to the reseivor using a single fitting.
The second reseivor on the rear panel left side. But this will block installing graphic cards or what ever on future expansion and I would have to drill 2 holes in the case to mount the reseivor.
How ever the reseivor would pop out of the brackets. Plus it would make the 2nd loop longer. I will mount the second Uber 655 pump next to the pump in loop one.
Advanages of mounting the reseivors on the radiaters. I would not have to drill any holes in the case.
I am concerned about effecting the air flow thru the rads and increasing the water tempreture if the reseivors are mounted on the rads.
I could leave out the reseivors and use 2 T fittings. I have read on the forums it is vary difficult to get the air out of the system.
Please give me some input on draining the 2 loops? I thought I could lay some towles in the bottom of the case with a bowl and disconnect the loops to drain the fluid every three months.
Should I install 2 fill ports? I have all the fittings for the fill ports.
Thanks
Thank you for your input and help.
Thanks
