D
Deleted member 9280
Guest
I've never really used SATA as a connection, always been using IDE. Now I have switched over, I can't in istall an OS. I go to install WinVISTA x64 and it formatted the drive fine. I go next and it says that the system volume couldnt be found or something. The computer then restarts. I have no other HDD with an OS on and manual mentions about RAID disk drivers. XP only will allow to Floppy.
My mobo is ASUS P5QPRO and HDD is 500GB Samsung I think.
Anyone help on how to install a OS on this SATA drive? Seems to be a bit on the tricky side for a simple installation.
Also does it matter what SATA number it's in?
Any specific settings in bios to change?
Please help
Thank you
Please help
Thank you
