SUPERFLY013
I have a coolermaster GX450w psu but I will be getting a Corsair HX750w Psu in feb after I take care of some bills then I can get a new video card. How much do you's think a 7970 will be after the amd 8xxx's come out?
A 450w would be fine with a 7850, so a power supply upgrade wouldn't be necessary. I wouldn't recommend upgrading in such short intervals though, either going for a 7850 now or a 7970 later would probably be a better choice, rather than both.I have a coolermaster GX450w psu but I will be getting a Corsair HX750w Psu in feb after I take care of some bills then I can get a new video card. How much do you's think a 7970 will be after the amd 8xxx's come out?
What power supply do you currently have? The HD7850 pulls a fair bit more power than the 6670, so make sure it can handle the extra load.
Haven't they fixed that already? I'm not too sure about this given there's a lot of different Sapphire 7850's, but it seems like the newer dual-x cards are using a different design from AMD's reference design which is seen with the second 6-pin PCI-e.
How is the 6870 I was looking at those as well
