I overclocked my cpu from 3.36 to 4ghz
was just concerned about the 8C temp increase...
My computer specs are:
i7 860
with H50 cooler.
Mobo: Gigabyte P55A-UD4P v2 Bios (F13)
Memory: 4GB Corsair Dominator 8-8-8-24 1.65v
Idle Temps:
#0 42C
#1 37C
#2 43C
#3 37C
Max load from #0-3 67C, 61C, 64C, 64C
I used OCCT and got a CPU too Hot! Error with HT enabled after 1hr 21mins
Also ran it without HT enabled and had no errors for 2hrs
Maybe I need more air coming into the case? I will try redoing the thermal paste tomorrow.
here's what I set in the Bios
CPU Clock Ratio - 20x
QPI Clock ratio - x32
Base clock (BCLK) - Enabled
BCLK Freq - 200
XMP - Disabled
System memory multi - 8.0
Cpu Clock drive - 800mV
PCI Express - 900mV
CPU Clock skew - 0ps
Intel T boost - Disabled
Cpu cores - ALL
Cpu M Threading - Enabled
CPU Enhanced Halt - disabled
c3/c6/c7 - Auto
CPU T Monitor - Auto
CPU Eist Function - Disabled
Bi Directional p. - Auto
Loadline Calibration - Disabled
CPU vcore - 1.275V
QPI vtt volts - Auto
PCH Core - Auto
CPU pll - Auto
Dram voltage - 1.6400v <-- (mobo doesn't have 1.65)
*The rest are on Auto*
Thanks in advance!
i7 860
with H50 cooler.
Idle Temps:
#0 42C
#1 37C
#2 43C
#3 37C
BCLK Freq - 200
XMP - Disabled
PCI Express - 900mV
Cpu cores - ALL
c3/c6/c7 - Auto
CPU vcore - 1.275V
PCH Core - Auto
CPU pll - Auto
Thanks in advance!
