Need a Fan Controllerrr!!!!
Firat
hey people,
now im in the process of building my rig which will be in a bitfenix colossus but i need a fan contoller with temperature sensing capabilities as the controller on the bitfenix doesnt let you control the fans independantly of each other so im stuck,
anyone know a decent fan controller that can let me control all the fans individually
well seeing ur other thread and you more than likely not going for huge overclocks i dont really see the need for it tbh, your temps will only be an issue if ur pushin it to its limits other than that with it being 32mn its all gonna run pretty cool in the first place
im shooting for a 4.7ghz overclock mayb not as a permenantly but well c just have to see what works
if your shooting that high what cooler will you have? cause the only option is the noctua nhd-14 if u expect to try and get there and not fry the chip cause of temps in the process
but as u said its not perm u can use software monitoring while you do it, and then once its back down lower u have no issues with temps cause u have a good cooler on there since u wanted to go high for a small run
if your shooting that high what cooler will you have? cause the only option is the noctua nhd-14 if u expect to try and get there and not fry the chip cause of temps in the process on stock cooling
NH-D14 all the way mate, cant have a rig without one. i wud never embark on a overclocking mission without noctua by my side
well thats good to hear mate, just stick with software since this isnt gonna be permanent and a short term oc and saves u having to piss about installing all the temp probes etc
