I am going to build my first water cooling rig.
I am nearly ready to start water cooling only a couple of things left to get (main one being my Asus Commando from RMA).
Please see the list and let me know if everything is covered.
I have;
CPU block Aqua Computer Cuplex XT DI 775
Eheim - 1250 pump
Black Ice Xtreme Radiator (single)
Criticool Power Plant Relay Card
½” pipe – Thanks Marcus
Cape Coolplex 25cm Reservoir
I need;
Feser One Coolant – Don’t know what colour though???????
Set of ½” barbs for the res.
(Possibly) double radiator
This is to be housed in a Thermaltake Kandolf case.
Questions;
I want a cool, quiet system so will I have to run the fan on the single rad at full pelt to keep the CPU cool as I will be over clocking?
I have the room to put a double rad in the front would this be a better/safer option?
I could always keep the single in the loop as well?
Eventually I will get a n/b block but not until the board has been tested for a while after RMA as I don’t want to return it again after messing with the original heat sinks as may have a detrimental effect on the guarantee.
This is (hopefully) going to be my completed setup.
Pump - Double radiator – CPU - Single radiator – N/B – reservoir - back to pump
Does this sound about right?
Any help/advice appreciated.
Dave (n00b).
I have;
Eheim - 1250 pump
I need;
Questions;
Dave (n00b).
