Hi guys,
After kilobravo suggested that i try a manual overclock not just a auto 4.4GHz one to get a better 3dmark11 p score this is what i came up with (below is what is set in the bios)
CPU = 3930k
MOBO = ASRock Extreme9 X79
Cooling = H100
BCLK = 100 MHz
Internal core pll over voltage = enabled
core voltage = 1.385V
LLC = LV5 (highest)
CPU PLL Voltage = 1.857V
What do you guys think, keep in mind this is my first manual OC. Heres a windows Screen Shot
(my 690 is overcocked +135%/+125/+555)
A few questions which one is the correct voltage(CPU-z/HWiNFO64) and what stability test should i do for my LGA 2011 3930k because i heard that prime is not the best for lots of threads on another video/forum, so far i have done:
Intel Burn Test - standard 10
3dmark 11 - performance
Folding At Home - 3 hours
CPU = 3930k
Cooling = H100
BCLK = 100 MHz
LLC = LV5 (highest)
