My HAFX Build
HafX
My updated hafx build. I just love how quiet this rig is. And quite powerful too, but im going to get 2nd N570GTX TwinFrozor PE/OC in couple of months so i get some more speed for gaming
Window view
Inside
GPU
Video
Not bad at all man, I actually just built a rig in a Haf-X case about a month ago, I love it so far. Just a tip though when you go to clean the side dust filter I recommend using Q-tips, I had to use about 4 but it did the job getting inside the side mesh.
[media]http://www.youtube.com/watch?v=Heb7OWUE5h4[/media]
Fixed the images and video for you.
Looks good and tidy, specs would be nice to know.
I had s9pro case before this it was mid tower so this was huge compared to that
so i liked to build this cause cabelmanagment was great and there was space to move things..
Thanks.. Specs are: CPU i7 920D0 @ 3.953Ghz 1.256V
GPU N570GTX TwinFrozor 3 PE/OC edition
700W Super Series by Chieftech
Mobo Asus Rampage 3 Formula
Ram: TeamGroup 6Gb 1600Mhz
Case: HafX
SSD: OCZ Vertex2 60Gb
HDD: Samsung F3 1TB
Nice rig
I also have the HAF X, but when i clean the dust filter on the side panel i normally just take the fan off and remove the filter to clean it.
Nice rig
I just use vacuumcleaner and suck dust from the outside and once in 3 months take the filter to proper cleanup...
Just finished of installing some bitfenix cable extensions made great iprovement
and FC5V2 fan controller and replased NH-D14 120mm fan whit 2nd 140mm fan and added 2x92mm noctuas sandwitched together in front bay to intake fan tunnel
<script src='http://imageshack.us/shareable/?i=img20110817220700.jpg&s=8' type='text/javascript'></script><noscript></noscript>
<script src='http://imageshack.us/shareable/?i=img20110817220717.jpg&s=5' type='text/javascript'></script><noscript></noscript>
<script src='http://imageshack.us/shareable/?i=img20110817220726.jpg&s=842' type='text/javascript'></script><noscript></noscript>
<script src='http://imageshack.us/shareable/?i=img20110817231001.jpg&s=845' type='text/javascript'></script><noscript></noscript>
