Been running for 32 minutes![]()
Although webpages are loading at a snails pace, and getting abit of lag.....
What do I put in problem size?
Dont use problem size.Use 1024mb ram or higher,and you will see problem size increase also.
I set RAM as 1024mb, and left problem size as it was (which is 11530)
I think its my PC that is lagging, mouse is a bit laggy at times
Try reboot,and let it settle 2min,before you start linx.
Ok is running now, I did a restart, but still get a bit of lag when running linx and when I was running prime......
With this linx on every run it starts from little CPU usage to 100% does this with every run unto 20, I'm guessing that's right?
I got a Stopped upon Error!![]()
Damn your CPU never gives up! xD
I would increase QPI to 1.34v
or what do you think kilobravo?
Tell me about it lol, it's a hard one to crack![]()
I havent changed anything but thought I'd run linx again, it is on number 4 ATM and still running gunna take a while to finish if it does, 11.30 in and on n#4, maybe just bad luck first time ??
Personally i don't believe in bad luck when running stress programsbecause if it fail on time and you run it again and it passes I still think its unstable
But as Kilobravo sad you will probably be good leaving your settings as they are now, you will probably not encounter any problems under normal day use.![]()
Sometimes a reboot or restart is enough to get it through.If it fails now,try with uclk 3400 and 1.36v on qpi.We are very close on all ram stable![]()
What about gaming though, getting ready for BF3 & COD MW3?
