right guys im goin A64 at xmas i i dont know what mobo to get its a abit AV8 3rd Eye or a msi neo 2 platinum its gonna be socket 939(obviosly) and a fx55 or a 4000 under my gt so wich oc`s best then doods
I also would try and wait till nforce4 comes!! Get the Asus Nforce4 SLI... then if you ever fancy going for an SLI array in the future you have the option,.. if not then you can still use one card at x16.
And defo go for the FX55 over the 4000+. The 4000+ is only an FX53 without the upwards multis... so you're better off getting a 2nd hand FX53 or a new FX55
Animal> Didnt realise you were a Norwich boy (im from Ipswich )
