But then the problem is the game producers. Why not just stop making them harder to run???
The GTX280 launched at 650$
So by that logic a Titan Xp should cost $700 and the 1080 should cost about half of that.
But its not 2007 anymore is it.
No, but as I said electronic goods usually become cheaper as time passes. Early 80s microwaves cost a month's salary or more. Now? you can get one for about twenty five quid.
Nvidia started it all with the Titan. Then AMD figured they would charge Nvidia cash for the Fury X (over £500, a new record from AMD apart from the dual core 7990 and 295 which was a grand !) and it's not changed much since.
Thats because they havnt really changed for years. we are talking about brand new tech that costs millions / hundreds of millions to do the background work on.
Thing is GPUs are becoming cheaper all the time.
If you got a GTX 980 when it first launched it would have cost you the best part of £500, if you want the same performance now you buy a GTX 1060 for a lot less.
Pascal may appear to be nothing more than Maxwell shrunken down, but we don't know how much that process cost or what was required to hit the ridiculous clock speeds. And while the chip sizes are relatively small, we don't know how much they are costing to produce, not precisely. The 1080Ti has 11GB of memory. That's enormous and likely costs a great deal. We can stipulate that Pascal was not a true architectural leap and thus shouldn't cost very much, but we simply don't know for sure what went into Pascal. And we don't even know if it was planned from the beginning. It may not have been listed on their initial roadmap, but that doesn't mean Nvidia hadn't conceived the idea. Maybe they were first testing to see whether it was going to be possible or whether they should just go straight to Volta. Whatever the case it's just stipulation. Nvidia's prices are due to a multitude of reasons, not just greed.
Okay, also on value loss?Titan has better resale value.
