dam that sucks :/ hmm gonna have to think of a new plan to get my things, thx for the reply![]()
first off no1 needs 6 cores, 4 core is over kill for most people.
if the price is right then there is no reason not to go hex
well native four cores.
the 1090t was aimed at the i7 930
amd hexcores would and will rape them chips
amd fan boy, look @ the specs AMD 2008 tech, 6MB L3, Intel core i3/i5/i7 2010 Tech, 8MB L3.
and AMD has been build the same way from 2003-2008(no 2009-2010 tech), there 2011 cores are 100% rebuilt, hoping to see if AMD will be better then Intel core i3/i5/i7 2010 Tech, or even beat or close to Intel 2011 tech.
AND note I do not like "FAN Boys" its stupid buy the best hate when people are all 100% AMD all 100% NEWEGG its stupid Buy the best you can, and shop around not all the time newegg has the best $.
who you calling a fan boy tell me different that the 1090t was not aimed at the i7 930.thats why i said if the price is right as ur original comment was 6 cores is overkill 4 is aswell
and you no it would mess up the i5.
dont call me a fan boy i have said on numerace occasions that intel hold the budget-midrange-high end flag so whats fan boy about that
1st off "Ghosthud1" said Drop it, 2nd off your name is AMDFTW and have a AMD logo for you avatar to me you look like a AMD "fan boy"
Dont even go down this road. ANY of you.
