i doubt this hasnt been asked before.
but is your BSOD stop code ending with "50"
And What voltages is your ram supposed to use and what voltages is it set to use..
"to me sounds like low voltage to the ram"
Here is one of the most recent ones after carrying out test in conjunction with Kingston;
Dump File : 072915-10921-01.dmp
Crash Time : 29/07/2015 9:49:02 PM
Bug Check String : DRIVER_OVERRAN_STACK_BUFFER
Bug Check Code : 0x000000f7
Parameter 1 : 00001c02`e5c23e6e
Parameter 2 : 00001c02`e5a93e6e
Parameter 3 : ffffe3fd`1a56c191
Parameter 4 : 00000000`00000000
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+150ca0
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+150ca0
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\072915-10921-01.dmp
Processors Count : 12
Major Version : 15
Minor Version : 9600
Dump File Size : 367,872
Dump File Time : 29/07/2015 9:51:09 PM
In relation to the XMP profiles and memory settings these are as follows;
XMP Profile #1: DDR4-3000 CL15-16-16 @1.35V
XMP Profile #2: DDR4-2666 CL14-14-14 @1.35V
Asus have suggested manually setting the memory timings 15-16-16-39 and the memory voltage to 1.35V which are the same settings the XMP profiles use and test the system again. They also suggested a faulty motherboard even but I have explained to them that Kingston tested on another identical mother board and memory kit and found the same issue.
Now Asus are advising me to ask Kingston to test the memory kit on other X99 series motherboards to see if they still have the same issues. To be honest I am over it I just want the memory kit replaced with one that has XMP profiles that actually work. I think they are playing the responsibility game as this is listed on the QVL under 3000MHz
