heh, paracord sleeving does look so nice, but yeah, lots of finger burns. I like your ghetto push-through toolnice work
On the 24 pin however, things won't be so easy...
...if you have to use coloured wires, why do you need to make it so hard to sleeve your PSUs Seasonic?!![]()
Your cables look really good. I like how the heat shrink is hidden.
I hope mine turn out like that.
Yeah, 24 pins are a PITA, although yours looks even worse than mine. All I had to
contend with were some sense wires (the double wires), nothing intertwined like
on your unit.
Have fun! :lol:
I think once the wires are sleeved and go more or less straight from one connector to the other, not crossed over like they came from the factory it will already look much better. As long as the mainboard side turns out tidy I'm happy. Your cable lacing video will definitely help me doing that.
Thanks, I didn't use heat shrink, it's not hidden. I only had to use it where two wires go in to one pin.
Check out lutroo's sleeving videos and you'd be able to make cables just like mine, it's really not that difficult once you get used to it.
Got the 24pin cable finally done today:
<very purdy>
The PSU side didn't turn out that tidy, but considering it will mostly be hidden, I think it's ok:
this cnc milled part looks much nicer than the plastic apple used
i hope you do the headphone jack ring to match![]()
Yes, yes it does.
I second that wish.![]()
