What you mean the
rubber O-rings? They're not acrylic
" NEVER use window cleaning fluids with ammonia (such as Windex or Formula 409), gasoline, denatured alcohol, carbon tetrachloride, or acetone, which will cause the acrylic to craze with minute cracks."
source:
http://www.e-tplastics.com/blog/how-to-clean-repair-and-protect-acrylic/
There's also other people/videos explaining about it, and I've had first hand experience with it happening.
It also tells you in the warranty information on some acrylic reservoirs not to use alcohol or it can damage it or it voids your warranty. It said so on the warranty of my res which cracked, but I didn't realise the coolant was. I assumed if it's so bad, why would any company use it in their coolant
Hm, very intriguing indeed.
To be certain, I just checked my bottle of DPU, and it says "1,2-Ethandiol" on it, which according
to Wikipedia is
Ethylene Glycol.
Also, Plexiglas actually does seem to be Acrylic (
link).
As for the list of chemicals in the article you've linked, none of them are actually Ethylene
Glycol as far as I can tell, so I'm not sure if that applies? Google has so far not yielded
any results, but considering how many names there are for both Acrylic and Ethylene
Glycol that does not surprise me, maybe I just haven't searched for the right combination
of synonyms yet.
In any case, if Acrylic really does respond badly to Ethylene Glycol, I'm now left to ponder
why the hell I've never even had the slightest problem? Or is it possible that there are traces of
other chemicals in DPU which are so low in concentration that they don't need to be listed,
but still high enough that they could do damage? I'm no expert in legalese though so I can't
say.
As a side note: I'm definitely not a chemist, so if I'm making some ridiculous mistake here
somebody feel free to point it out.
EDIT:
Well I was going on you saying it was because the coolant contained alcohol. Alcohol breaks down o-rings does it not?
That makes more sense :lol:
I think some rubbers are sensitive to alcohol, others not so much. In any case, is Ethylene
glycol actually alcohol?
