AlienALX
Well-known member
I originally named it this because of black, and black, and black with a tiny bit of red. However, someone else came up with a much better reason.
Because it has a 1 tear-ear-bite hard drive.
WIP pic.
OK so the one thing that has driven me utterly spare with this case is the feet. Or rather, the ten minute feet. That is about how long they lasted.
If you look up at the pic with the arrows on you will see what this case had for feet. Four rubber pads. Rubber and carpet don't mix, so within ten minutes all four had ripped off completely. I was then ed off every time I tried to move it, as the bottom panels are held in with poppers and a screw. However, now that it has nothing for feet they continually catch the carpet as I move it around and pull out. I was literally just waiting for something to bend or snap.
So I kinda left it there. Every time I work on it it gets heavier and heavier so I asked my pal with some nice machines to make me something out of 10mm black acrylic. He obliged.
They've been deliberately chamfered to stop them catching the carpet. They're 70x70mm, so nice and chunky. When I take it home I will put some 3m felt pads (that you get for chair legs) on them to make them slide on the lino.
WIP pic.
