mayhem
Asus Sabertooth X58 Socket 1366 8 Channel HD Audio ATX Motherboard
Intel Core i7 950 3.06GHz Socket 1366 8MB - Overclocked to (4.138 Ghz) http://valid.canardpc.com/show_oc.php?id=1812058
12 GB G-Skill DDR3 2133Mhz RipjawsX Memory Kit CL9 (9-11-9-28-2N) 1.6V
Heat Killer CPU WC Block Upgraded to 1366 fittings
2 x 120mm Rad
Pump + Res XSPC
4 x 1.5TB Samsung f1's now in raid stripe and mirror
2 x Mushkin 60Gb Ssd's (raid strip) Weekley backups and restore via Auto Ghost (this keeps the speed and takes only 7 min)
need a new case, the Sabertooth is in no way water cooling frendly and needs fans to cool down the chip set. Ill figure out a way of doing this some time.
Hd speed is mental
- Had to put on the normal side pannel for the case so that i could have 2 x 120mm fans blowing on the chip set to cool it down.
Takes 5.2 seconds to boot into windows from cold bioot "After" raid array have passed. Every thing flys real fast and open before you can blink.
By using ghost to back up the SSD raid to the Samsung F1's then move it back again keeps the SSD's in top form and negates this problem with trim. Since it takes less than 7 min to do its a very small price to pay for the speed im getting.plus the fact i dont listen to any one and do things my way
2 x 120mm Rad
Pump + Res XSPC
Hd speed is mental
