Mayhems Pastel UV White or ANY UV clear?
The_Governour
I am looking for a nice UV coolant for my loop, I all ready have some white tubing but I was thinking to change to clear tubing and some UV clear or UV white as it shines more and in my opinion looks nice.
Anyone have any experience with Mayhems Pastel UV White?
Or is there any other UV white or clear that is better??
I'm pretty sure the pastel colours deteriorate quicker than other coolants like EK Lime Green (UV green). If you regularly change your coolant then its not a problem.
Although I don't know of anyone who has had colour issues with the pastel white. Hopefully it doesn't turn brown ;)
I would not change the coolant that often, as the loop is very big - 480 x 2 and 360 x 2..... But I would like to know what coolant is good as UV, but only clear OR white UV. I have the green UV and its nice and bright.
I have used several mayhems pastels and overall they have been fine.
The only time I have had a problem with Pastel white is recently and it seems like that is down to me being sent some bad hose. As long as you choose your bits well and ensure you get what you are after you should not have a problem
I'm curious why you need so many radiators too be honest.
I am building a PC Desk and going full over kill with the water cooling - as a matter of fact then I am about to order another 480 Monsta rad to make it look more even...... ;)
After it is finished I guess I wont have to bother about high temps ever again.... ^_^
