Well here it is at last.
Completed....apart from finishing the reinstall and benchmarking and overclocking
I apologise for the quality of the pictures. Try as I might I just can't get them to do justice, especially with the lighting effects. So rather than try yet again for better shots i've made a (rather poor - using my camera) short video which can be downloaded here (10mb) -might take a little while to d/l as it's only a free hosting service.
cosmosgloria.wmv
Anyways, here are the photo's
Bottom of case lighting to give a nice white glow underneath the case
and with the internal white cathodes on, rigged to a sound controller
Just the main 10" UV's + the UV LED's in the pump housing and in the bottom of the res.
Although it doesn't show it too well the transparent uv blue nail varnish that I used on the perspex does give a nice sharp line which delineates the window nicely.
I have also yet to get the lcd display working but I am sure that that will be just a matter of time.
I may also have to swap some of the rad fan out for some more powerful ones as the temps are a little high - at idle coolant is 32*c with fans on full. I reckon that if I put the old psu fans in there then I should be able to drop that to closer to 25*c. Shall see what happens when I bench it and how high the core and gpu temps get.
Not 100% sure that I'll keep the picture behind the drive bay blanking plate. Possibly a bit too busy so may change it out for a rather nice galaxy photo that is a lot darker. The original hope was that the uv would shine through the edge of the perspex and highlight the stars more than it actually does. Oh well, Live and Learn.
So thankyou for your time and comments in following this log. They have been welcomed.
Let 'us know what you think of it.
I am sure that there is much more that I can and probably will say about the build but its one forty in the morning and I am knackered.
Thanks Again
Maju
