Now onto the fun stuff. Fitting the radiator.
I've been thinking about this for quite a while and eventually have come up with this.
As seen earlier i'd made up some perspex mounting plates as the existing fan mount holes arn't suitable for what I needed to do, plus I needed to cut some of the case away so as not to block the rad.
So some measuring and masking later i'm good to go
and I only hope that this works coz it's too late now
One of the downsides of using such a thick piece of acrylic is that i'd need long screws to attach the radiator - 46mm to be exact and after searching in all the home hardware stores locally realised I was buggered as they didn't have them and I couldn't find them on the net either. So a bit of improvisation was called for.
Have ended up using 50mm electrical socket screws which I have cut down to size.
Also found that I needed to brace the heads when I was cutting them as even though most of it was in the wood it still bent.
Of course, rarely in life is anything so easy. The electrical screw are 3.5mm width so I had to drill out the fan holes on the radiator with a 3.2mm drill and then thread the holes.
Worthwhile though as it works.
Next up, because of the way that the mounting holes in the cosmos are set into indented recesses in the top panel it meant that there would be a 2.5mm gap around the top of the inner mounting plate. Fortunately I'd kept the soundproofing from the side panel and it's perfect for making a gasket to maintain an airtight (ish) seal. So the order of assembly
To make fitting everything together easier I stuck the gasket onto the panel using doublesided tape and then stuck that panel to the rad using only a couple of small bits of tape - as it's all got to be disassembled agian before final fitting. I may also cut another gasket to fit between the rad and the mounting plate.
I found it easiest to fix the middle fan first. This way you aren't putting excessive starain on the fan mounts on the rad whilst you're screwing it all together.
And a little while later I have this.
And although premature I couldn't resist just to get an idea of what it would look like
I reckon it looks pretty good. It was also just as well that I did try the shroud as with the fan grills on it was catching in a couple of places so I need to trim the shroud. This can be avoided if you use a thinner piece of mounting material - say 3mm acrylic.
I also had a nice surprise. Instead of a boring technical sticker on the back of the fans the is a simple sticker with a triangle. I kind of like this as it matches my tat
Not that i'm vain at all.
Anyway for all of you other cosmos owners that might be thinking of doing the same I hope that this might be of some use. I know I found very little when looking for relavant how to's on the net.
Lets see what tomorrow brings
