Ok, im nearly there. As in ready to order parts etc. i have a tendency to over think things at times
and this looks like one of those times!
Need a bit of advice, first water cooled set up going into this build, and i could use some advice as to roughly what size rad would be needed to cool a 3570k over clocked and a 7970 overclocked. i have in my head a couple of 240 rads, thinking this might possibly be seen as overkill but like i say i want the quiet factor... I would appreciate advice here as to how much OTT this is lol
this now leads me to part 2 of my "help request" here, the case.
I was tempted with the nzxt switch, but i really would like something smaller, i need room for an optical drive, i need to burn discs regularly so i cant get away from it, i would also love it if i had room for a dual bay res as i have seen a really sexy one im in love with :wub:
and part 3... every previous build i have done i have used a fan controller, TTL frequently mentions using adapters for 3/4 pin fans in reviews. can someone linky this sort of thing to me so i can get my head around it. my google-fu is failing me today.
TLDR:
1.) what size rad for a 3570 + 7970 (minimum)
2.) any mid tower case recommendations with water cooling in mind
3.) how can i wire fans without a fan controller and not using MB headers (being a numpty and showing inexperience here im sorry)
thanks in advance peeps!
TLDR:
