I was bored over christmas so put a 2500k, a 6870 and a temp psu in this just to get it up and running.
Its really messy, but it will start to come along soon when I pick up my psu that has just been delivered to komplett in Ireland so just have to pick it up
and when sr-3's start to become available
, hating the wait for this
I have it running at 4.6ghz stable with temps maxing in there 50's with very low rpm fans. I'm really happy with that especially with 16gb ram at 1700mhz so dont think will overclock it more (hope i can get the same from this cpu when I put it in my htpc and have it on air).
The ram will be changed to either white or black lp vengence ram just not sure which yet depending on what way. (Would anyone any ideas which would look best?).
I'm not sure whether to sell this ram or replace the 4gb mushkin in my htpc with it but think it would be wasted in such a machine.
I was bored so redid my other machines that are in my room also. The 690II will be watercooled soon also but wont be overclocked as its mainly a workstation. It will used as a gaming rig only when having lan games with mates so probably only once a week/forthnight.
With the server I know its an odd way to put the res but it works fine and keeps the air out while allowing enough flow and allows the fill port to be used as a drain port also so will leave it like that until I replace it with a drive bay one.
