Hi guys! I'm looking to liquid cool my next custom build for overclocking purposes. Components used in the build are:
CPU: i7 4770K
GPUs: 2x MSI GTX 780 ti 3GB
Case: Phantom 630 (with window)
RAM: 32GB Corsair Dominator Platinum 2133
SSHDs: 2x 2TB Seagate Hyrbid SSHD
SSDs: 2x Samsung Evo 840 250GB
PSU: Corsair AX1200 Gold
DVD Drive: Pioneer 15x Blu Ray
(I thought I would give as much information about my build as possible).
I'm looking to watercool the CPU and both GPU's. Would I be correct in saying that two radiators are needed for a cooler flow? Or would you even go as far as three?
This is what I was thinking so far: http://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=266733&action=wish_lists
If all that is compatible with eachother, can someone please suggest what tubing, fittings, coolant, etc. to use? Preferably referencing back to PCCG stock.
I'm still constantly reading watercooling guides but if someone could just double check my list and/or add to it, that would be appreciated! Any suggestions are welcomed.
CPU: i7 4770K
