Laing DDC 18 Watt Capable???
leejc73
Hi All,
I'm just wondering if I need to consider a second pump in my system or if the Laing will be up to it?
I will be running 2 x 240mm Rads, XSPC Rasa Block and a EK FC-GT200b.
So what do you lot reckon??
You will be fine with that pump
a 2nd is not needed, the only blocks you have is Gpu and CPU, radS don't restrict flow. Same as ttl's snow drift build he had a Gpu, CPU block and 2 rads with only that pump, have a quick look at it!
Hope that helps
Thanks buddy, I figured it would be enough after testing it, but just wanted to confirm.
Got all the other bits now, just got to spray up the rad tanks/plates before it goes in.
