Has anyone got any experience with US layout boards?
Would love UK one but simply cannot afford thos kind of prices but have seen several cheap ones but all have the US layout.
That's the only difference. The only real annoyance personally comes from the smaller enter key, special characters after that are rarely used so are fine as far as I'm concerned.
Personally I prefer the swapped @ and " 's on the US layout because it makes more sense to me that way around.
However the lack of gbp sign can be a pain. But easy # on the 3 instead of the gbp isn't necessarily bad. I use # way more than I do the pound sign so it's meh.
If you switch between the two a lot, you'll find yourself preemptively hitting enter a lot when you meant to hit ' slightly bigger shift key is also nice. Tbh, try it
Well its not much different pressing right alt and 4 to pressing shift and 3. When I moved to Norway I had a tricky time getting used to Nordic layout. Now i cant live without it, I prefer it over UK layout. More available keys too.
