VoraciousGorak
well first of all i run my 2500k at 4.8GHz. also if you are using the "FAH GPU Tracker V2" (which i recommend you do) go to Setup-->Configure and there i have the following checked:
enable cpu folding
use multi-core smp client
use all cpu cores
add -advmethods
disable hiding clients
enable gpu folding
enable gpu0
gpu3 client
nvidia fermi
add -advmethods
(from top down on the left and the top down on the right)
try those setting and see what you get, if u don't see an improvement try OC-ing a little more, remember if you cooler can handle it most people agree that it is 24/7 safe to run ur cpu at 1.37V (personally i have it at 1.33 in bios because i found it was the best oc/heat)
I doubt the GPU settings have much to do on the CPU side, this PC has a 6950 anyway. I'll try the "Disable Hiding Clients" setting, but my 4.2GHz vs. your 4.8GHz should only be a 14-15% difference.
Maybe memory speed, I'm running mine at 1600 right now? I didn't think that had a lot to do with it.
