Hi guys, some of you may remember around christmas 2010 i posted about my Haf X Project, and never really updated the thread afterwords with how things turned out. Anyway i renamed my project to the Xieron project, and it has been through a few different versions since then. Here are the various version with specs below and what i still have planned, as usual feedback and suggestions are much appreciated
Xieron Mk 1:
Specs:
Motherboard - Gigabyte Gaming GA-EP45T-UD3P
GPU - ATI Saphire HD6850 1GB
RAM - OCZ Reaper 6GB (2 x 1gb, 2 x 2gb)
CPU - Intel Core 2 Quad Q9550 @ 2.31Ghz
PSU - Galaxy 1000w PSU
HDD - 2 x WD 350GB, 1 x WD 500GB
COOLER - Stock
Here are some pictures of it:
Shortly after adding the LED strip:
Dark Shot:
Rear cabling, messy lol:
Xieron MK 2:
This was after i had an upgrade of components, this was a few months before christmas, around octoberish.
Spec:
Motherboard - Asus Rampage II Extreme
GPU - MSI N560GTX Ti OC Twin Frozr II
RAM - Kingston HyperX Genesis 12GB (2 x 6GB)
CPU - Intel Core i7 940 @ 2.93Ghz
HDD - 2 x WD 350GB, 1 x WD Caviar Green 1TB
Cooler - Antec Kuhler H20 920 liquid cooling
Up until christmas 2011 i originally had a BeQuiet Dark Rock Pro cooler, and was still using the HD6850, but i was fitting the Asus Kuhler on christmas day and broke the 6850, which was later replaced with the GTX 560 ti im using now.
Here are the latest pics (Cabling is as tidy as i can get it atm):
And in teh dark:
The LED on the pump has been changed to red
Hope you all like it, i plan on an MK 3 or an MK 2.5 as i want to sleeve the cables in blue, which i will be buying at the end of the month, and i will be swapping out the red LED fans for blue ones as well as adding blue cold cathodes
Xieron Mk 1:
Specs:
COOLER - Stock
Dark Shot:
Xieron MK 2:
Spec:
And in teh dark:
