So I’m thinking of chopping up my CM storm enforcer case so that I can fit a 200mm radiator and another 200mm fan at the front of my case and then I was thinking about putting a double 5" drive bay reservoir above it and so on, it will involve removing the hard drive bays and maybe removing one of the 5" bays, then i can move the hard drive cage towards the PSU and once that is done I am thinking about putting a false floor in covered in carbon fibre vinyl sheet.
Do you guys think that it will be a good idea or not?
Also what are the best tools for the job? i was thinking a dremel but i can get hold of most tools no problem.
This will be my first case mod but it shouldn’t be a problem because it’s a fairly simple case mod and I’m pretty good with my hands.
**im not sure if this is the right place to post, please correct me if it isnt**
