Savage_Smithy
My 1TB hard drive has pretty much had it, SMART errors and the other day it decided it was a 32MB RAW disk. I have now got it working again and got a replacement caviar black. the problem now is i want to transfer a lot of files from the dying disk to the new one but simply copying them from windows isnt an option because some files simply will not be read properly and it will freeze up the entire transfer. the only other way is to copy 1000's of files one at a time and then skip the ones that wont copy, most of the time i have to restart windows explorer to stop it trying to copy the file.
So is there a utility that can copy the files for me and automatically skip over the ones that cause issues?
thanks,
smithy
thanks,
smithy
