Hard Drive gone to "Raw" format
Hi Everyone,
Need a pointer if there's any software that can help me fix this problem.
The Hard Drive is a 2TB Sea Baracoda and I use this for copying data and I connect this via a docking station I just used this drive the other day and a day or so ago the drive had gone into spasim mode and had gone RAW so there's no file system associated with the drive.
I connected the drive directly to the motherboard and also in my External Enclosure all say Raw and it happily spins away but I can't access the contents of this drive.
In event viewer it says:
An error was detected on device \Device\Harddisk7\DR8 during a paging operation.
so any help would be great!
Cheers
Rob
