LiamTheBoss
Hi guys, I have found an EVGA gtx 580 3gb for 250 pounds. Can someone tell me if i should get this? I mainly play Battlefield 3. Thanks in advance.
will it work ??? i have a phenom x4It's worth checking http://www.Gumtree.co.uk as well, there are 580s from £180 on there
http://www.gumtree.c...ngdom&ubercat=1
If there is one in your area you could always ask to see it working before you buy, for example this one.
http://www.gumtree.c...tx-580/99290892
will it run with an AMD cpu
It will as long as your motherboard supports Nvidia cards, some of the older ones don't but all modern ones do, I think they do anyway, i'm not to clued up on AMD stuff.
250 pounds!! GOOD GOD! will your PCI socket hold that much weight?![]()
Yes, but not SLI.
990FX boards do both now.
I didn't think 990FX had support for AM2.
